Elm. Change ntp server.
Hi.
I have elm and cucm installed on the save virtual host. I want change ntp server address on that host. Do it need to generate net license after tha or not ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Purple
Hi ,
No.
  • In case of VMWARE, use 8 to 9 parameters to generate a license MAC. Even if you change any one of the parameters, such as NTP Address or the Time Zone, the license MAC will change. Then, you need to procure new licenses. However, with this Enterprise License Manager in place, even if you made those changes you do not have to worry about the licenses. There is a product instance that has already been added to the ELM. Even if you make any changes, it will grab the required license from ELM.
you can also refer the link
https://supportforums.cisco.com/docs/DOC-27483
regds,
aman
1 REPLY
VIP Purple
Hi ,
No.
regds,
aman
237
