ELM Web Interface missing menus
I've just installed my first test ELM (9.1.2.10000-28)
I can login to the elm-admin application. But once logged in, I see no menus. I get the title bar, but nothing else.
I've tried this on both Chrome & Firefox.
Has anyone seen this before?
GTG
Please rate all helpful posts.
1 ACCEPTED SOLUTION
VIP Purple
Hi Ross,
this could be the issue.
ELM GUI not displaying on Chrome 29+ and Firefox 25
CSCul30396
Symptom:
ELM GUI does not display properly, only the page header is visible.
Conditions:
User is trying to access ELM using the latest version of Chrome or Firefox.
Workaround:
The ELM GUI displays properly on both Internet Explorer 9 and 10, as well as Safari (Mac and Windows).
regds,
aman
VIP Purple
Hi Gordon,
Have u installed on separate server or co-resident with Publisher ?
Did u try using ELM on IE 8?
regds,
aman
VIP Purple
Hi Ross,
CSCul30396
Symptom:
Conditions:
Workaround:
regds,
aman
Doh!
Just need for that release to hit Cisco.com.
Thanks for the pointer.
GTG
Hi!
Ii've installed a dedicated Cisco Prime License Manager with version 10.0.1.10000-19 but the bug is NOT FIXED in that release, hence the info inside caveat CSCul30396 is wrong - It says fixed in  10.0(1.98000.25) and 10.0(1.98000.38).
So the bugfix got lost in the FCS build.
The available patch elm_SoftwareUpdate_v1.cop.sgn is not valid for PLM (as already the filename says). I tried it out but it is not a supported ugprade file, hence PLM 10.0 cannot be used with Firefox 25+ and Chrome 29+
BR,
Christoph H.
Sorry, it's a separate VM. I used the 9.1 OVF, with the 7,500 user node configuration option. (Yeah, it's overkill, but let's start with too much first...)
GTG
1471
