EM-HDA-6FXO cisco module :Type of cable and connector
Please could someone give me the type of cable and connector which I have to connect to the EM-HDA-6FXO module in other to connect the PSTN lines to a Cisco voice gateway 2821 ?
Thanks in advance !
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: EM-HDA-6FXO cisco module :Type of cable and connector
Preferentially, you will need the BlackBox JPM2194A patch panel with RJ21 cables, as indicated in the data sheet:
http://cisco.com/en/US/products/ps5855/products_qanda_item0900aecd8016c487.shtml
Else, any RJ21 cable and patch panel will work.
As a recognition to those providing answers, please rate useful posts using the scrollbox below!
that module does not have connectors because it is inserted as daughterboard into another module called EVM-HD-8FXS/DID. It cannot be used without.
If you need 6 FXO ports, and do not want the mdoule above, use 1 x VIC2-2FXO and 1x VIC2-2FXO.
Please,
Can you tell me which connector and cable do I have to connect to EVM-HD-8FXS/DID module in other to connect PSTN lines to a voice gateway ?
1436
