Community Member
Email alerts for RTMT
We are getting alerts from RTMT that a Gateway has increased or decreased, but it doesnt state which one. Is there a way to get the alerts on which gateway is going down?
Everyone's tags (2)
1 REPLY
Community Member
Re: Email alerts for RTMT
I had the same issue with not enough information out of the gate.   I just created a custom alert.   I went to Performance then selected the server the gateway was register to and navigated to Cisco MGCP Gateways -> PRISpansInService.   After you get the graph up you can create your own custom alert with custom text that has better speciffics.
Obviously this could be a little different if you're running SIP or H323 and not a PRI.
637
