Emergency Service - Cisco Emergency Responder
Hi!
Would Cisco Emergency Responder work well in another country with a different emergency number (not 911)? Would it be possible having in mind a voice network with several CM6 to physically locate and identify the terminal that is making an emergency call?
Hall of Fame Super Silver
Re: Emergency Service - Cisco Emergency Responder
Yes it will work in another country with any emergency number you want.
CER history reports display what device dialed emergency number, the device details contain switchport assignment, so you can easily tell that device on particular switch connected to particular port dialed the number.
HTH,
Chris
Ok. Thanks.
Just one more question:
With possible equipment mobility is it guaranteed that we'll have correct and real time information in what concerns physical location?
Ana
check out "Defining the phone tracking and switch update schedule" section here:
http://www.cisco.com/univercd/cc/td/doc/product/voice/respond/res13/admin13/e911conf.htm#wp1074562
HTH, please rate all helpful posts!
Chris
144
