04-05-2009 11:45 PM - edited 03-15-2019 05:19 PM
In the configuration guide it states that the mobility softkey when not in a call can be used to disable or enable the mobile connect feature.
However, this softkey is not working. All the other things are working fine. The user has to enable/disable this feature using the user options web page.
When you press the mobility softkey, it just says: "MobileConnectOn".
I have read several things on this forum, but nobody came up with a solution. I don't want a workarround, I want a working softkey as described in the config guides.
Best Regards,
Wouter Eelen
Solved! Go to Solution.
04-06-2009 12:13 AM
which version of cucm u have?
04-06-2009 12:13 AM
04-06-2009 12:17 AM
HI Wouter,
It should work only in CUCM v7
kr
jp
06-16-2009 03:54 PM
I have the same issue in version 6.1.x, i just tested in version 7.x and works fine.
06-29-2009 10:48 PM
I have the same Issue also on CUCM 6.1(3)
but I also it work fine on CUCM 7.0(2)
So Please if anyone come to idea Please Post it
06-30-2009 02:43 AM
I have the same problem in 6.1(3)
but its working in 7.0 and 7.1
Any ideas?
