11-30-2008 10:13 PM - edited 03-15-2019 02:49 PM
Version Information:
c2800nm-spservicesk9-mz.124-11.XJ.bin
The issue is that when the night service bell is activated and then deactivated on a 7970 phone, that phone's call forward option is automatically set to a strange number without the user actually doing anything. It only happens with a 7970, and it happens in at least three sites that have been tested, and presumably more. If customer uses another phone they do not see a problem. Customer has tried setting the phone's template to disable forwarding and that has no effect.
Please see attachment 7970.doc
11-30-2008 10:15 PM
11-30-2008 10:17 PM
11-30-2008 10:24 PM
At least at 3 sites which customer has tried and the same number always comes up as the cfa:
On enable/disable of the night service bell triggers the problem
Router 1 - cfa 040873688
On Router 2 - cfa 180075
On Router 3 - cfa 0
Partial Config - See the two sho ephone outputs - one after removal of cfa at the end.
Sh ephone
ephone-10 Mac:001E.BE90.877C TCP socket:[26] activeLine:0 REGISTERED in SCCP ver 9 and Server in ver 8
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:10.129.212.146 52826 7970 keepalive 90449 max_line 8
button 1: dn 10 number 100 cfa 040873688 CH1 IDLE CH2 IDLE shared
button 2: dn 5 number B91 CH1 IDLE
button 3: dn 3 number 99 CH1 IDLE CH2 IDLE shared
button 4: dn 105 number 506 CH1 IDLE monitor-ring
button 5: dn 106 number 507 CH1 IDLE monitor-ring
button 6: dn 114 number B516 CH1 IDLE
button 7: dn 115 number B517 CH1 IDLE
button 8: dn 2 number *01 CH1 IDLE monitor-ring shared
telephony-service
load ATA ATA030203SCCP051201A
load 7921 CP7921G-1.0.4
load 7931 SCCP31.8-2-2SR1S
load 7961 SCCP41.8-2-2SR1S
load 7970 SCCP70.8-2-2SR1S
load 7906 SCCP11.8-2-2SR1S
load 7911 SCCP11.8-2-2SR1S
extension-assigner tag-type provision-tag
max-ephones 85
max-dn 160
ip source-address 10.129.215.254 port 2000
max-redirect 10
aut{09:12:35}__o assign 150 to 158
timeouts interdigit 6
system message Coles Capalaba
time-zone 47
date-format dd-mm-yy
max-conferences 8 gain -6
hunt-group report url prefix tftp://172.31.144.109/sq8759ar101-
hunt-group report url suffix 0 to 200
hunt-group report every 24 hours
hunt-group logout HLog
multicast moh 239.0.0.1 port 2000 route 10.129.212.129 10.129.212.193
web admin system name ccme secret xxx
transfer-system full-consult
transfer-pattern 00.........
transfer-pattern 03.......
transfer-pattern 04.......
transfer-pattern 05.......
transfer-pattern 06.......
transfer-pattern 07.......
transfer-pattern 08.......
transfer-pattern 09.......
transfer-pattern 8.....
transfer-pattern .T
secondary-dialtone 0
night-service code *01
directory entry 1 600 name Customer Call
fac custom ephone-hunt join *3
fac custom ephone-hunt cancel #3
fac custom ephone-hunt hlog-phone ##5
create cnf-files version-stamp 7960 Oct 24 2008 14:26:38
ephone-template 1
softkeys hold Resume Newcall
softkeys idle Redial Newcall Gpickup HLog
softkeys seized Redial Pickup Gpickup
softkeys alerting Endcall
softkeys connected Endcall Park Trnsfer Hold Confrn
softkeys ringing Answer
type 7970
ephone 10
description Operator
ephone-template 1
provision-tag 100
mac-address 001E.BE90.877C
type 7970
no auto-line
button 1:10 2:5 3:3 4:105
button 5:106 6:114 7:115 8m2
night-service bell
ephone-dn 10 dual-line
number 100
pickup-group allPhones
label Customer Calls 100
description 3900-3700
name Checkout Manager
call-forward all 040873688
call-forward max-length 0
corlist incoming STDPagingCalls
huntstop channel
night-service bell
ephone-hunt login
sh ephone 7970{09:15:16}__
{09:15:17}__
IP:10.129.212.146 52826 7970 keepalive 90455 max_line 8
button 1: dn 10 number 100 CH1 IDLE CH2 IDLE shared
