Enable Only The Speakerphone
We have Call Manager 8.6.2 and 7945 IP Phones.  The verbage used to discribe enabling/disabling the headset and speakerphone is sort of confusing.  I have in my configuration:
[X] Disable Speakerphone
[X] Disable Speakerphone and Headset
   The ? Help says:
   Disable Speakerphone - Disable only the speakerphone fuctionality.  Disabling speakerphone functionality will not affect the headset....
   Disable Speakerphone and Headset - Disable all speakerphone functions and headset microphone.
I am not sure if the following will enable the Speakerphone ONLY.
[  ] Disable Speakerphone
Or must I remove the X from both.  The Help makes me think I can't have the Speakerphone only.  The phone is at a remote site and I can't just walk over and do a quick operational check.
Thanks in advance for your responses.
Everyone's tags (6)
Hall of Fame Super Red
Hi George,
Just tested this out for you and you are most correct
The "Disable Speakerphone and Headset" does disable both so you
cannot enable Speakerphone only.
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Hall of Fame Super Silver
You cannot disable HANDset, only Speakerphone and headset.
HTH,
Chris
Re: Enable Only The Speakerphone
Thanks guys.  This is good to know.  I appreciate the testing and fast response.
Kind Regards
George
156
