Enable Web Access on bulk Cisco 69XX
Hi all,
I have a problem for a big migration, i need enable the Web acces on my 69XX series. But when i use the enterprise phone configuration and common phone configuration the web access is not enable. only manual configuration on the phone works. And in the bulk this option is not present.
Do you have any idea for allow this parameters on all phone?
regards
Vincent
  • IP Telephony
1 ACCEPTED SOLUTION
Looks like other types of
Looks like other types of phones/models are included in the bulk selection(like CTI port etc). Look for 'Device Type' 'Contains' '6941'. This should only list out model 6941 phones and 'web access' enable should be available. If not, please provide more info on this-version of CM, number of phones, firmware etc.
-Sunil
-Sunil
I have worked on this issue,
I have worked on this issue, and is necessary to fixe at one modele of phone for modifiy this parameter.
Thank's for your help and patience.
regards
1. Through Enterprise phone
1. Through Enterprise phone configuration, we can enable web access for all the phones.
2. Through Bulk, we can enable web access for particular model / device pool of phone
(BAT --> phones -->update phones --> query)
305
