Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Enabling GUI on Callmanager Express
I have gns3 running on my laptop. I simmulated GUI on the the vg which run on the gns3. when i attempt to brouse into it, it asks for my username and password. but when i supply the information, it only display a blank page. I need help
Re: Enabling GUI on Callmanager Express
Did you try to use Internet Explorer?
Yes, it is internet explorer that i'm using.
Contributions please !!!!!
Did you copy all the GUI files into flash on the GNS3 Simulated router?
Also are you browsing to http:///telephony_service.html
If you are not using the URL above, it will try to default to the HTTP configuration page of the router.
Bill.
120
