Enabling meet-me on 9971 99xx on CME SIP
I have a 9971 phone I've successfully registered on CME 9.1.  I'm trying to enable additional soft keys such as meet-me, Conf, and park on the 9971 however I'm running into some issues.
I've read the guide at http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesoftk.html#wp1011897
and tried to create a voiec register template 1 as below -
voice register template  1
softkeys seized  Redial Endcall Cfwdall Meetme
softkeys connected  Confrn Endcall Hold Park Trnsfer
camera
video
and applied this on the register pool of the 9971 as below -
voice register pool  2
id mac xxxx.xxxx.xxxx
session-transport tcp
type 9971
number 1 dn 2
template 1
dtmf-relay rtp-nte
username user1 password 123456
codec g711ulaw
camera
video
however when I pick up the handset, I do not see any of the options I enabled above - "Redial Endcall Cfwdall Meetme"
Any suggestions will be appreciated.  Thank you.
Everyone's tags (4)
1 REPLY
Hall of Fame Super Red
Hi there,
We don't run any 9971's on CME but I did find this an interesting question
It looks like the 9971 is treated differently than other models;
Feature Policy Soft Key Control
Cisco Unified CME 8.5 allows you to control the display of soft keys on  the Cisco Unified SIP IP Phones 8961, 9951, and 9971 using the Feature  Policy template. The Feature Policy template allows you to enable and  disable a list of feature soft keys on Cisco Unified SIP IP Phones 8961,  9951, and 9971. Table 79 lists the controllable feature soft keys with specific feature IDs and  their default state on Cisco Unified SIP IP Phones 8961, 9951, and 9971.
Table 79     Feature IDs and Default State of the Controllable Features
Feature ID
Feature Name
Description
Default State on CME
ForwardAll
Forward all calls
Enabled
Park
Parks a call
Enabled
iDivert
Divert to Voicemail
Enabled
ConfList
Conference List
Disabled
SpeedDial
Abbreviated Dial
Disabled
6
Callback
Call back
Disabled
7
Redial
Redial a call
Enabled
8
Barge
Barge into a call
Enabled
Cisco Unified CME uses the existing softkey command under voice  register template configuration mode to control the controllable  feature soft keys on phones. Cisco Unified CME generates a featurePolicy.xml file for each voice register template configured. The list of controllable soft key configurations are specified in the featurePolicy.xml file.  Phones need to reboot or reset to download the Feature Policy template  file. For Cisco IP phones that do not have a Feature Policy template  assigned to them, you can use the default Feature Policy template file  (featurePolicyDefault.xml file).
As we see above MeetMe is not one of the softkeys that can be modified in this manner,
so then I looked for a different method and found this CUCM doc that speaks directly to Meetme on 9971's
Configure the Meet-Me Option on a Cisco Unified IP Phone 9971
http://www.cisco.com/en/US/products/sw/voicesw/ps2156/products_configuration_example09186a0080b9b500.shtml
In this doc we see that in CUCM the following is true;
Configure
The Meet-Me option is configured as a feature button and not as a       soft-key.
For the 9971 device model configuring softkeys is completely different       than the usual 79xx models: the Cisco Unified IP Phone 8961, 9951, and 9971 do       not use softkey templates in Cisco Unified Communications Manager       administration. Here, "feature control policies" are used which allow the       administrator to limit the appearance of features on the Cisco Unified IP Phone       8961, 9951, and 9971 by disabling them in Cisco Unified Communications Manager       administration.
Feature Control Policies allow you to enable or disable a particular       feature, and control the appearance of certain features and softkeys that will       be displayed on the phone. When you disable a feature, the softkeys for the       disabled feature do not appear in any call state.
The Meet-Me feature is a Programmable Feature Button which requires       configuration in Cisco Unified IP Phone administration. The Programmable Line       Keys (PLKs) as SoftKeys feature enables the administrator to provide certain       features to users as either softkeys or buttons on the phone.
These features are now available as either PLKs or SoftKeys:
  • Call PickUp
  • Mobility
  • Malicious Call Trace
  • Meet-Me
  • Quality Reporting
Because in CME we've previously seen that the Feature Control Policy doesn't include MeetMe
it looks like the only option would be PLK's. So I would try this method in CME;
SIP: Configuring Feature Buttons on a Line Key
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesoftk.html#wp1035649
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
2486
