enabling outgoing caller ID - restriction
I m using call manager 4.2.1 and trying to enabling outgoing caller ID for some of the route pattern.
Since some of the route pattern needs to show caller ID while some needs to show as "Private". I have set up the following:
Calling Line ID Presentation : restricted
Calling Name Presentation: restricted
Route group setting:
Use Calling Party's External Phone Number Mask : DEFAULT
Gateway ( outbound call) :
Calling Party Presentation: default
My problem is, its still showing the caller ID even i have restricted it in the route pattern level.
Any idea?
kind regards
Rachel
Hall of Fame Super Gold
Re: enabling outgoing caller ID - restriction
Do you have ISDN ? If so, take a debug isdn q931 with term mon and post it here.
VIP Super Bronze
These are the settings I have used in the past for this and it did work.
1.calling party presentation...restricted
2.calling party IE number type unknown...unknown
The rest were left at default values. This is set on the gateway in callmanager.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
156
