enabling parked calls to be picked up by outside callers
I have a client and they want to have the ability to have parked calls picked up when they dial in to the main auto attendant.  I'm not sure of how to design the auto attendant so this works or what the best practice for something like this is.
Can anybody help me out?
Thanks!
Ryan
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: enabling parked calls to be picked up by outside callers
Depending on your CUCM version you may be able to accomplish what you need.
If you are using standard Call Park then javalenc is correct  there would be no way to do this in a way that was actually useful to  the end user.  However, depending on your requirements, you may still  have a viable solution available.  You could leverage Directed Call  Park.   With Directed Call Park a user that is "parking" the call can  specify the "park" number.   Then, you could have your AA application  provide IVR options so that you can retrieve the "parked" call easily.
So,  a sample scenario:
Partitions:
mypark_pt:   Partition that will hold the directed park numbers
You  need to make sure that this partition is visible from the phones that  will park the call and the Unity voicemail ports which are used to  retrieve the parked call.
Directed Call Park DN:
You  create a directed call park number (Call Routing->Directed Call Park) and specify parameters that work in your environment.  For example:
Number:  108123X
Partition: mypark_pt
Retrieval Prefix:  *03
Note: you may want to specify reversion information as well (and look at CUCM service paramters related to park while you are at it)
AA Call Handler:
Create a call handler that has a callers input menu like so:
Keypad 1:  transfer to *031081230
Keypad 2:  transfer to *031081231
Keypad 3:  transfer to *031081232
...and so on...
Create a greeting that tells the user what to press.
If you want this Call Handler to stand by itself, then you will need a DN assigned to this rule and then a way in CUCM to redirect callers to the Unity system.  In Unity leverage routing rules or the Call Handler extension with the existing/default Unity forwarding rules to direct the caller to the Call Handler.  I am going to assume you know how to do all of this.
If you want this Call Handler to be an option on your AA application, then create the keypad option in your AA application that sends callers to the "Call Park" call handler.
Walk Through:
1. Caller calls Phone_A
2. Phone_A  answers the call
3. Phone_A wishes to park the caller using directed call park so the user of Phone_A uses the Transfer soft key and then dials: 1081230.  After dialing the park number, Phone_A hangs up
4.  The Caller hears MoH or ToH per your design and is "parked"
5.  Admin_A calls the "Call Park AA" application on Unity and gets prompted to "press 1 for parked number 1, press 2 for parked number 2, etc."
6.  Admin_A presses "1" and then unity transfers Admin_A to *031081230  (the *03 tells CUCM this is a retrieval action)
7.  Once the transfer is complete the original Caller is talking happily to Admin_A
This will require heavy user training and still isn't something I would promote doing, but you asked if it could be done and how one could approach it.  I doubt you care about my opinion on whether you should or not ;-)
Hope that helps.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Unless you only have 1 call park slot i see no way this can work, call park slots are used in round robin and the whole point is the phone shows which DN you need to dial. The won't know which one to retrieve.
Just dialing the AA cannot do that (unless only 1 slot is used), you would need to configure caller input or call system transfer and know beforehand what to dial.
No best practices, call park was created thinking you would call park the call and see what DN to dial afterwards. Never to be retrieved by an AA.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Partitions:
Number:  108123X
AA Call Handler:
...and so on...
Walk Through:
Hope that helps.
Bill
334
