Enabling Trasncoding on CME
I tried to enable a Transcoding DSPFarm for CME itself, I have tried this same setup for Conference DSPFarm and it worked but I don't why got the  error: Cause Code: TCP_CONN_ERROR. I have tried to follow some advice seeting up a Loopback but still didn't worked.
I have realized with another CME with a working transcoding DSPfarm that I should to be able to make a telnet to port 2000 and be able to see the sccp process running listening at the same port too but I was unable to do it.
Below the CME setup:
voice-card 0
dspfarm
dsp services dspfarm
sccp local Loopback0
sccp ccm 192.168.100.1 identifier 1 priority 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CME_TRANSC
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 2
sdspfarm tag 1 CME-TRANSC
max-conferences 8 gain -6
transfer-system full-consult
CME-Legacy#show ip int brief
FastEthernet0/0            192.168.4.2     YES NVRAM  up                    up
Serial0/2/0                192.168.3.2     YES NVRAM  up                    up
Loopback0                  192.168.100.1   YES NVRAM  up                    up
CME-Legacy#show sccp
SCCP Admin State: UP
Gateway Local Interface: Loopback0
        IPv4 Address: 192.168.100.1
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.100.1, Port Number: 2000
                Priority: 1, Version: 4.0, Identifier: 1
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 4, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
CME-Legacy#
CME-Legacy#show dspfarm profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE IN PROGRESS
Application : SCCP   Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
CME-Legacy#
CME-Legacy#sh control-plane host open-ports
Active internet connections (servers and established)
Prot               Local Address             Foreign Address                  Service    State
tcp                        *:23           192.168.4.1:61966                   Telnet ESTABLIS
tcp                        *:23                         *:0                   Telnet   LISTEN
tcp                      *:1720                         *:0                    H.225   LISTEN
tcp                      *:5061                         *:0         CCSIP_TLS_SOCKET   LISTEN
tcp                      *:5060                         *:0                      SIP   LISTEN
udp                      *:1975                         *:0                      IPC   LISTEN
I shoulded see this connection open (this is from a CME's trancoding DSPGfarm working fine)
tcp                     *:16089            10.32.29.12:2000         SCCP Application ESTABLIS
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(3)T3, RELEASE SOFTWARE (fc1)
Any help would be appreciated!!!
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: Enabling Trasncoding on CME
Mohammed,
Yes I can confirm that the adding max-ephone 5 and max-dn 5 enabled the trabnscoder to register. Like I said I accidentally deleted Leos response to the post which confirmed it was the correct answer. Hopefully he will re-rate the post again.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
No worries mate .... Main thing to fix problems better than rating
"If you find this post useful, please rate it"
VIP Super Bronze
Your profile association seem to be wrong
sccp ccm group 1
telephony-service
sdspfarm units 5
Either change your profile to
associate profile 1 register CME-TRANSC
or your sdspfarm tag to
sdspfarm tag 1 CME_TRANSC
Both your profile and sdspfarm tag should match
Thanks for the respond, I retyped the name but still got the same result:
CME-Legacy#show run | s telep
telephony-service
sdspfarm units 5
CME-Legacy#show run | s sccp
sccp
sccp ccm group 1
        Port Number: 2000
IP Precedence: 5
Any idea?
VIP Super Bronze
Hi. Try and shutdown sccp and re enable it by doing
No sccp
Sccp
I did it after have retype the name but I got the same result.
Anyidea?
VIP Super Bronze
Leo,
I have accidentally deleted most of the replies including Mohammed's suggestion and all your ratings for the post. Mohammed will re-post. Can you please rate his posts again...and any of mine you find helpful
No worries , i just wanted if it fixed or not.
Just checked my mail and found its fixed ... I am posting the answer again for reference.
You need to set max-ephone and max-dn to bring the telephony service up. Those are mandatory configurations. You was missing them from your config.
VIP Super Bronze
Mohammed,
Great Answer it resolves the
Great Answer it resolves the problem of mine.
1326
