Community Member
Encryption between 2 Ip Phone
Is it possible to encrypt communication throught 2 IP Phone interconnect with a CME ?
My IP Phones are 7906 and 7911.
Thanks in advance
Olivier
Bronze
Re: Encryption between 2 Ip Phone
CME 4.2 supports this feature.
device-security-mode
To set the security mode for SCCP signaling for devices communicating with the Cisco Unified CME router globally or per ephone, use the device-security-mode command in telephony-service or ephone configuration mode.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeauth.html
Community Member
I'm in CME 4.2 with 7942, 7911 and 7906 IP Phone and when I put the
ephone xxx
device-security-mode encrypted
command then the IP Phone could not register on the CME
=> Here is the message on the IP Phone " Registration Rejected : Max Phones ...3
and the one on the CME
Feb 15 19:31:09.091 UTC: %IPPHONE-6-REG_ALARM: 24: Name=SEP001EF7C2BC4D Load= SCCP42.8-3-2S Last=Phone-Reg-Rej
Feb 15 19:31:10.087 UTC: %IPPHONE-6-REG_ALARM: 22: Name=SEP001EF7C2BD1E Load= SCCP42.8-3-2S Last=Reset-Reset
when I remove the device-security-mode encrypted, the IP phone register immedialtly but without sRTP ?
any idea
thanks in advance for your help
Olivier
You have to do the steps mentioned in the doc in the other post. It's more then just enter the one command...
Phone Authentication
•Configuring the Cisco IOS Certification Authority (required)
•Authenticating Certificates for Server Functions (required)
•Configuring Telephony-Service Security Parameters (required)
•Configuring the CTL Client (required)
•Configuring the CAPF Server (required)
Media Encryption
•Configuring Secure Calls Between Cisco Unified CMEs Across an H.323 Trunk (required)
•Configuring Cisco Unified CME SRTP Fallback for H.323 Dial Peers (optional)
Good luck,
Martin
Community Member
Has anyone found the solution for this ? I'm looking at exactly the same error when "device-security-mode encrypted" in CME7.
Regards.
509
