Encryption Voice Call CCM 4.1
What parameters I have to configure to enable encriptaion of calls in the Call Manager Server, version 4.1?
Super Bronze
Re: Encryption Voice Call CCM 4.1
lots of steps, which vary depending which products (gateways/phones etc) you have. Read the security guide for starters:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/4_1_3/sec413.html
While you are reading that, you also need to order 2 KEY-CCM-ADMIN-K9 security keys to enable the cluster for 'mixed mode' security. No keys, no encryption.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
To encrypt the calls between two IP phones just enough to set the value Device Security Mode to Encrypted?
After you go thru the whole process of creating the CTL file and using the 2 USB keys, getting the file to the phones... yes.
If you mean if you can just go right now and try to change it without the USB tokens and creating the CTL file, then no.
The whole process is outlined in the link Aaron posted, have you gone thru it?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
162
