Endpoint showing unknown for registration status
I'm using CUCM 6 and have setup a test voice gateway. I am using MGCP to control the gateway. The call manager reports the E1 endpoint registration status as unknown yet I can make calls out via the E1 PRI.
Here is a shown ISDN status
test-mgcp-rtr#show isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not appl
y
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 3
Total Allocated ISDN CCBs = 0
The MGCP config is
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
Can anyone hep me understand why the status shows as unknown?
Help rated.
Gavin
Re: Endpoint showing unknown for registration status
You may need to restart the Realtime Information Service (RIS) to clear up the discrepancy, and sometimes restarting the TFTP service helps as the TFTP service the gateway is using to auto-configure has gotten stuck and cannot complete.
You may want to check this against:
show ccm
show mgcp endpoint
hth,
nick
Thanks Nick, I deleted the voice gateway and added it again, this seemed to resolve the issue.
Silver
Having the same issue here.
I already tried restarting RIS as this had caught me before. Also, if I do a ccm switch back to the backup server it shows as registered in CCM admin.
Tried TFTP after seeing this, but it didnt help.
When I switch back again it goes back to unknown.
Was there a bug id for this behaviour in 6.1(3)?
Calls still seem to be fine though.
Cheers,
Tim.
728
