EndUser Associate Device Profile to Extension Mobility LDAP
I have a CCM 7.1.3
My CUCM is integrated with Microsoft AD integration and LDAP authentication.
Devices need to associate my Profiles with end users to use Extenssion Mobility
Is there any way we can associate end users with IP phones via BAT?
or I have to assign each end user with Devices manually?
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
2 ACCEPTED SOLUTIONS
Re: EndUser Associate Device Profile to Extension Mobility LDAP
Yes.  You can update user objects to associate devices and device profiles.  You essentially re-import users using a .csv file.  In the .csv file you can identify fields that should be ignored and those that should be updated based on values you provide.  Take a look at the following to get the specifics on how to proceed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/7_0_1/t04upusr.html
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Super Bronze
No - you use your UserID attribute (which may be your AD username if you selected sAMAccountName as the userID property when configuring the LDAP sync) as your user ID.
You use the PIN from the CallManager user pages for EM; there is no PIN attribute in AD.
You would use your AD password for logons to PC Applications (Agent Desktop, CUPC for example) and web apps such as CCMUser.
Aaron
Please rate helpful posts...
This email communication does not create or vary any contractual relationship between Logicalis and you. Internet communications are not secure and accordingly Logicalis does not accept any legal liability for the contents of this message. The contents of this email are confidential to the intended recipient at the email address to which it has been addressed. It may not be disclosed to or used by anyone other than this addressee, nor may it be copied in any way. If received in error, please contact Logicalis on the above switchboard number quoting the name of the sender and the addressee and then delete it from your system. Please note that neither Logicalis nor the sender accepts any responsibility for viruses and it is your responsibility to scan the email and attachments (if any).
Logicalis UK Ltd, Registered in England and Wales No: 3732397, Registered Office: 110 Buckingham Avenue, Slough. Berkshire, SL1 4PF
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
HTH.
Bill
is  functioning normally
For me  to use the Extension Mobility service, after the LDAP integration.
I use my  username and password coming from the AD to login?
Example:
username:  adm.brangel
password: 123456
Super Bronze
Aaron
Thank`s
So to  activate the service I have to go in manually and set end user?
Ok Thanks
942
