Enterprise Attendant console - Sync with Active directory "company" field?
Is it possible to sync the "Company" field in the Enterprise Attendant console with the "Company" field in Active Directory?  I have LDAP sync enabled in CUCM.
I don't see "company" as a “source field” option from the drop-down list in the AC server for Directory Field Mapping. It seems strange that this field would be overlooked, especially in the Enterprise console.
On a related note since many applications sync with CUCM and not directly with AD – is there a list of what fields are synced between CUCM and Active directory?  I know more is synced than what is visible through CUCM “end users” and “LDAP directory”.
CUCM 7.15
CUEAC 8.6.2.11
Everyone's tags (2)
1 ACCEPTED SOLUTION
I found the answer as to which AD fields are synced that you don't see from the CUCM console.  See table 12-2 in the following link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b02lddir.html#wp1075347
That explains why "pager" is synced all the way to CUEAC, and not company - although that doesn't make logical sense to me.
I think I'm outa luck.  If CUEAC pulls from CUCM, and CUCM doesn't pull the AD fields I need, then I can't expect CUEAC to have the fields I need either.
I'm told that the premium attendant console can pull directly from AD, maybe I'll look into that.
Hall of Fame Super Red
Hi Jonathan,
Thanks for posting back with the results of your investigation here. Much appreciated.
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
1537
