06-27-2012 07:04 AM - edited 03-16-2019 11:52 AM
Hi All,
I just upgraded a customer to 8.62 and we added Enterprise attendant console.
It looks like its working. They are able to answer calls, transfer, see status etc.
however when they transfer a call in the software the call is transferred and the caller hears ringing. However it does not actually ring the physical phone. it just rings and rings.
if you transfer using the phone itself or dialing the number in the software it works.
it only doesn't work when you click and drag the call
I double checked calling search spaces and made sure all ports are associated with the ac user
any thoughts?
06-27-2012 07:15 AM
More details
If i change the client to do a consult transfer it works. However if i keep it as a blind transfer it does not work
06-27-2012 07:20 AM
Try this - On the PC were the console client is installed, go into the registry and then HKLM\Software\Arc Solutions\Call Connect\Operator\Defaults. Under the default section look for the "Direct Transfers" key, change its value to "All" and reboot the PC.
06-27-2012 07:35 AM
im in the registry now and do not see a direct transfer key
i see a Server Based Blind transfer
and that is set to YES
06-27-2012 07:39 AM
I am assuming that console client has been opened and used on this machine already. As long as that has been done and the ID you are using to log into machine has admin access, then you should see it. I know this may sound dumb but you could try to reboot it as well. All of my 8.6.2 CUEAC clients machines have this key.
06-27-2012 08:38 AM
I see the registry value. It is off
i changed it to All
rebooted the computer
when i look at the registry is now says On
the blind transfer still does not work
any other ideas?
thanks
06-27-2012 10:53 AM
That is wierd only due to the fact if you changed it to "All" it should say "All" and not "Yes".
06-27-2012 10:55 AM
it actually changes it to On
have a tac case open now
08-16-2012 01:37 PM
Were you able to solve the problem ? I'm facingthe same.
thanks
08-16-2012 03:08 PM
We got it fixed. what i had to do was on the Template in call manager that you create for the attendant console, make sure you have the busy trigger higher than 1 and the max calls higher then 1 too.. I think we did busy trigger 2 then max calls 6
