entry directory on cme not working
Hi Experts
I have strange issue in CME. I have configured the entry directory under the telephony service but when the users try to get these directory is not shown to them. I shows an old extension and name and even when searching by name it is not shown. Please advice it is important .
  • IP Telephony
VIP Gold
Try to update cnf file after
Try to update cnf file after configuration changes and after that restart one of IP phone and check.
use below command under telephony-service
create cnf-files
Suresh
Hi Suresh Thanks alot for
Hi Suresh
Thanks alot for your post I did do the command create cnf-files and restart one phones but still not working. Is there any idea. Appreciate your help.
VIP Gold
Hi Bin,Please go through
Hi Bin,
Please go through below CSC forum, it may help you.
https://supportforums.cisco.com/discussion/11563566/local-directory-not-showing-when-using-cme-86
Suresh
VIP Gold
Attach `show run` as well
Attach `show run` as well please.
Suresh
show run is attached
VIP Gold
give "ip http server" in
give "ip http server" in global config mode and put below command under telephony-service and then check plz.
service local-directory
Suresh
Hi I have did that also not
I have did that also not working any other idea please
I have exactly the same
I have exactly the same problem.
It worked fine and then directories are no longer available.
Have you found a solution?
Oooops, my bad, see this link : https://supportforums.cisco.com/discussion/11563566/local-directory-not-showing-when-using-cme-86
and this :
same problem for me with 2921 running IOS 15.2(4)M2 with CME 9.1
I had to do the following :
no ip http access-class 23
no ip http server
access-list 23 permit
ip http server
After that, local directory work fine.
JC
HiI have tried also the same
I have tried also the same but still not working :(
164
