03-11-2009 12:29 PM - edited 03-15-2019 04:46 PM
I've got one big list of cards and equipment that i would like to check for End Of Life End Of Support info.
Instead of searching for every equipment in www.cisco.com is there anyway better to get this info?
Thanks for your comments and help,
Rgds,
Met.
03-11-2009 12:31 PM
If you cisco AM cares about you, he will collect all the info for you. Of course the hope is that you evenually make orders :)
03-11-2009 12:56 PM
ah, of course, but.. that is not the way, since it is a lot of equipment for the internal database.
Doubts:
1. Is it necessary to search equipment by equipment on Cisco Site?
2. There is equipment without any announcement. Is it normal, or there always have to be defined dates for EOSale/Support?
Thanks for your help,
Met.
03-11-2009 01:01 PM
Hey Met,
Thie search through this area isn't too bad :)
Like Paolo nicely noted, it would be nice if your AM or SE would search this out for you ....but (better safe than sorry :)
Cheers!
Rob
03-11-2009 02:31 PM
Rob -> as always...your answers are really helping!
Thanks!
Best regards,
Met.
