EPBX Remote Use
sreekanth sarma
Hi all i am using VOIP solution in a campus lan environment where all the VOIP Phones have EPBX as thier Gateway,and the EPBX is connected to PSTN for dialling outside,I have Public IP natted for the EPBX Gateway,can i use this Public IP any means in coordination with VOIP Software that sits on a Remote Home Computer user who uses Remote Access VPN for dialling purposes.....
please reply me as i am new to VOIP and need solution for my VPN
5 Replies 5
paolo bevilacqua
What is the EPBX exactly ?
And what Remote Access VPN are you using ?
I am using ASA based remote Access VPN with AES and SHA , i dont know exactly about the EPBX as am new to campus i have to search for it , will it be possible?
Yes, it should be possible.
Please remember to rate useful posts.
Can u help me in this regard i will get more information for EPBX and other
You will need help from who manages the EPBX, not myself.
