03-31-2008 02:21 PM - edited 03-15-2019 09:45 AM
Hi there,
This is an issue on cme. I have an ephone-dn. When it is assigned to a button, it receives calls but cannot make calls. A 'debu ephon det mac' is attached. Can some explain the debugs?
Thanks in advance.
Solved! Go to Solution.
05-20-2010 08:44 AM
TAC found bug CSCtc01185 recommeded upgrade to 15.1(1.16)
05-20-2010 01:10 PM
Thanks for the updates.
05-21-2010 06:30 AM
I haven't tried the upgrade yet. Unfortunately I won't know for weeks it worked since take awhile to happen. On a side not after looking at the bug I see it lists the version my customer is running 12.4.24T3 as being fixed.
05-09-2013 05:26 PM
Hi mate,
We are running 15.2 and we just got the above issue for the first time on one of the 7942 units.
Same issue " Chuan Liu" had.. I cannot delete the DN as it spits out "DN xxx has active call on interface 50/0/xxx CH1 Cannot unconfigure"
Jecket@technologyarch.com mentented using the "clear call voice" command, please explain (what do you mean by ID) ?
05-10-2013 06:26 AM
Unfortunately that doesn't work for the issue on the new releases. I maintain ccme/uc500 systems across many different loads and this seems to happen on all of them from time to time. I don’t know for sure but I believe it happens if a phone is say on a call or ringing and it resets. Setting the lease time on DHCP to infinite has helped one site where I was having issues of course, I have never been able to induce the problem. I have only found 2 ways past it on newer 15+ releases.
2 options I use.
05-12-2013 02:55 AM
Hi Jeckert,
Thank you for the quick reply.
I do like option 1, which I will perform tomorrow ..
However, if this happens again, we might have to look at a reload..( we have not performed a reload before and any instructions you would provide use would be appreciated)
Thanks mate.
03-21-2018 12:18 AM
Has anybody found solution on this problem?
My cme router is 2901 and cme is 10.5. I am also facinf the same problem.
Amol Wable
