12-08-2011 08:53 AM - edited 03-16-2019 08:27 AM
I have a Cisco UC560 with Call Manager Express/IOS 15.1(2)T2 and am trying to configure an ephone-hunt group using multiple ephone-dns with the same number, statically overlaid onto the secondary line of agents' phones. The relevant config is as follows:
ephone-dn 109
number 313
label IT
name IT
no huntstop
ephone-dn 110
number 313
label IT
name IT
preference 1
no huntstop
ephone-dn 111
number 313
label IT
name IT
preference 2
no huntstop
ephone-hunt 4 longest-idle
pilot 303
list 313
final 8161
timeout 30
description IT HG
ephone 8
device-security-mode none
mac-address E8B7.4815.831C
max-calls-per-button 2
type 504G
button 1:22 2o109,110,111
ephone 9
mac-address E8B7.4815.8247
type 504G
button 1:24 2o109,110,111
ephone 10
mac-address E8B7.4815.65CC
type 504G
button 1:25 2o109,110,111
Calls to 303 successfully ring on all agents phones, but after the first call is answered, any further calls to the hunt group receive busy treatment even though the other dns are free to take it; hunting doesn't take place. I have other ephone-hunt groups (1-3) with a similar configuration (but different dns and numbers) which work fine.
UC560#sh ephone-hunt 4
Group 4
type: longest-idle
pilot number: 303, peer-tag 20121
list of numbers:
313, aux-number A303A0300, # peers 3, logout 0, down 0
on-hook time stamp 966942500, off-hook agents=0
peer-tag dn-tag rna login/logout up/down
[20120 111 0 login up ]
[20119 110 0 login up ]
[20118 109 0 login up ]
only one agent available!
final number: 8161
preference: 0
preference (sec): 7
timeout: 30
description: IT HG
hops: 1
E.164 register: yes
auto logout: no
stat collect: no
callqueue display: continuously
debug: no
I note it says only one agent available - why does it not recognise that there are effectively 3? Anyone have ideas? I have already tried setting the last dn to huntstop which doesn't help.
Solved! Go to Solution.
12-09-2011 03:46 AM
Just a correction to what I posted
Hunt-pilot dosn't work and behaves as you mentioned (first call rings all and second gives fast busy).
..but calls to 439 (overlaying dn) work as I told you.
First call rings all and second call goes to other phone (second line)
Carlo
12-08-2011 09:49 AM
Hi Jim,
I can't find anywhere that notes that overlaid DN's aren't supported in
ephone-hunt group configs but the only way I could see this working
is if the system would allow this change;
pilot 303
list 313,313,313
final 8161
timeout 30
description IT HG
Cheers!
Rob
12-09-2011 01:10 AM
Hi Rob,
No joy with that:
UC560(config-ephone-hunt)#list 313 313 313
Number 313 appears more than once in list.
The other hunt groups I have do hunting fine with a single number in the list, which is the odd thing. Their show ephone-hunt X outputs don't look different in any unexpected way.
The effect I'm looking for is described at http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1099687 - it all works if I give each DN a different extension number but the documentation suggests that shouldn't be necessary.
12-09-2011 02:30 AM
Hi Jim.
In your original config try to add huntstop channel i your ephone-dn.
Your config should be as follow
phone-dn 109
number 313
huntstop channel
label IT
name IT
no huntstop
ephone-dn 110
number 313
huntstop channel
label IT
name IT
preference 1
ephone-dn 111
number 313
huntstop channel
label IT
name IT
preference 2
Carlo
12-09-2011 02:34 AM
Hi Carlo,
They're single line DNs so this is not allowed:
UC560(config-ephone-dn)#huntstop channel
Dual-line mode is required
Is it worth trying with dual-line DNs even though this (http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_e1ht.html#wp1065555) says it's not appropriate to use them for huntgroups?
Anyone know any useful debug commands to try and potentially see where it is falling over in real-time?
12-09-2011 03:38 AM
Hi Jim.
I tried the following config in my LAB and it works fine.
ephone-dn 1
number 430
label Agent1
name Agent1
ephone-dn 2
number 431
label Agent2
name Agent2
ephone-dn 9
number 439
label HG
name HG
no huntstop
ephone-dn 10
number 439
label HG
name HG
no huntstop
ephone 1
mac-address 001A.6D2A.9C22
type 7940
button 1:1 2o9,10
ephone 2
mac-address 0011.21D8.9A19
type 7940
button 1:2 2o9,10
ephone-hunt 1 longest-idle
pilot 438
list 439
When I call 439 firs call falls on 430 and second in 431.
You can try it and let me know.
Carlo
12-09-2011 03:46 AM
Carlo
12-09-2011 04:37 AM
Thanks Carlo,
That makes sense. Although, it sounds like by dialling 439 you are bypassing the ephone-hunt group config altogether (is it even required?) - how would you go about implementing a "final" number to fall back to if all the agents are busy, or a timeout for the same if they are not answering.
12-09-2011 05:28 AM
Hi Jim.
No ephone-hunt will be no longer necessary.
Using my config I would apply a call forward rule both for unanswered and busy calls
ephone-dn 9
number 439
label HG
name HG
no huntstop
call-forward noan 8161 timeout 15
call-forward busy 8161
Carlo
12-09-2011 06:22 AM
Which dn would you configure those forwards on? I guess you would use preferences and then place it on the least preferred one?
12-09-2011 06:25 AM
As you can see in my last post, call forward is configured on shared (overlaying) dn.
Carlo
12-09-2011 06:27 AM
Sure, but in your previous example, both ephone-dn 9 and 10 are shared and overlaid. Which one of those would you put the forward on?
12-09-2011 06:41 AM
Sorry.
Being a "shered line" on both dn will apply call forward rules.
Carlo
12-09-2011 06:55 AM
Sorry if I'm being stupid - are you saying the forwarding needs to be applied on both, or that applying it on one will work for all the shared dns.
I would have thought that applying it on only one would mean it didn't take effect if that dn was in use at the time and the call was therefore ringing on one of the alternative dns?
12-09-2011 07:29 AM
Hi Jim.
Sorry for my bad Explanation
Yes call forward rules have to be applied on both shared line ephone-dn 9 and ephone-dn 10
Carlo
