ephone-hunt group not hunting
I have a Cisco UC560 with Call Manager Express/IOS 15.1(2)T2 and am trying to configure an ephone-hunt group using multiple ephone-dns with the same number, statically overlaid onto the secondary line of agents' phones. The relevant config is as follows:
ephone-dn  109
number 313
label IT
name IT
no huntstop
ephone-dn  110
number 313
label IT
name IT
preference 1
no huntstop
ephone-dn  111
number 313
label IT
name IT
preference 2
no huntstop
ephone-hunt 4 longest-idle
pilot 303
list 313
final 8161
timeout 30
description IT HG
ephone  8
device-security-mode none
mac-address E8B7.4815.831C
max-calls-per-button 2
type 504G
button  1:22 2o109,110,111
ephone  9
mac-address E8B7.4815.8247
type 504G
button  1:24 2o109,110,111
ephone  10
mac-address E8B7.4815.65CC
type 504G
button  1:25 2o109,110,111
Calls to 303 successfully ring on all agents phones, but after the first call is answered, any further calls to the hunt group receive busy treatment even though the other dns are free to take it; hunting doesn't take place. I have other ephone-hunt groups (1-3) with a similar configuration (but different dns and numbers) which work fine.
UC560#sh ephone-hunt 4
Group 4
    type: longest-idle
    pilot number: 303, peer-tag 20121
    list of numbers:
        313, aux-number A303A0300, # peers 3, logout 0, down 0
            on-hook time stamp 966942500, off-hook agents=0
            peer-tag  dn-tag  rna  login/logout  up/down
             [20120     111    0       login      up  ]
             [20119     110    0       login      up  ]
             [20118     109    0       login      up  ]
    only one agent available!
    final number: 8161
    preference: 0
    preference (sec): 7
    timeout: 30
    description: IT HG
    hops: 1
    E.164 register: yes
    auto logout: no
    stat collect: no
    callqueue display: continuously
    debug: no
I note it says only one agent available - why does it not recognise that there are effectively 3? Anyone have ideas? I have already tried setting the last dn to huntstop which doesn't help.
1 ACCEPTED SOLUTION
Just a correction to what I posted
Hunt-pilot dosn't work and behaves as you mentioned (first call rings all and second gives fast busy).
..but calls to 439 (overlaying dn) work as I told you.
First call rings all and second call goes to other phone (second line)
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hall of Fame Super Red
Re: ephone-hunt group not hunting
Hi Jim,
I can't find anywhere that notes that overlaid DN's aren't supported in
ephone-hunt group configs but the only way I could see this working
is if the system would allow this change;
pilot 303
list 313,313,313
final 8161
timeout 30
description IT HG
Cheers!
Rob
Hi Rob,
No joy with that:
UC560(config-ephone-hunt)#list 313 313 313
Number 313 appears more than once in list.
The other hunt groups I have do hunting fine with a single number in the list, which is the odd thing. Their show ephone-hunt X outputs don't look different in any unexpected way.
The effect I'm looking for is described at http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1099687 - it all works if I give each DN a different extension number but the documentation suggests that shouldn't be necessary.
Hi Jim.
In your original config try to add huntstop channel i your ephone-dn.
Your config should be as follow
phone-dn  109
number 313
huntstop channel
label IT
name IT
no huntstop
ephone-dn  110
number 313
huntstop channel
label IT
name IT
preference 1
ephone-dn  111
number 313
huntstop channel
label IT
name IT
preference 2
Carlo
Hi Carlo,
They're single line DNs so this is not allowed:
UC560(config-ephone-dn)#huntstop channel
Dual-line mode is required
Is it worth trying with dual-line DNs even though this (http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_e1ht.html#wp1065555) says it's not appropriate to use them for huntgroups?
Anyone know any useful debug commands to try and potentially see where it is falling over in real-time?
Hi Jim.
I tried the following config in my LAB and it works fine.
ephone-dn  1
number 430
label Agent1
name Agent1
ephone-dn  2
number 431
label Agent2
name Agent2
ephone-dn  9
number 439
label HG
name HG
no huntstop
ephone-dn  10
number 439
label HG
name HG
no huntstop
ephone  1
mac-address 001A.6D2A.9C22
type 7940
button  1:1 2o9,10
ephone  2
mac-address 0011.21D8.9A19
type 7940
button  1:2 2o9,10
ephone-hunt 1 longest-idle
pilot 438
list 439
When I call 439 firs call falls on 430 and second in 431.
You can try it and let me know.
Carlo
Carlo
Thanks Carlo,
That makes sense. Although, it sounds like by dialling 439 you are bypassing the ephone-hunt group config altogether (is it even required?) - how would you go about implementing a "final" number to fall back to if all the agents are busy, or a timeout for the same if they are not answering.
Hi Jim.
No ephone-hunt will be no longer necessary.
Using my config I would apply a call forward rule both for unanswered  and busy calls
ephone-dn  9
number 439
label HG
name HG
no huntstop
call-forward noan 8161 timeout 15
call-forward busy 8161
Carlo
Which dn would you configure those forwards on? I guess you would use preferences and then place it on the least preferred one?
As you can see in my last post, call forward is configured on shared (overlaying) dn.
Carlo
Sure, but in your previous example, both ephone-dn 9 and 10 are shared and overlaid. Which one of those would you put the forward on?
Sorry.
Being a "shered line"  on both dn will apply call forward rules.
Carlo
Sorry if I'm being stupid - are you saying the forwarding needs to be applied on both, or that applying it on one will work for all the shared dns.
I would have thought that applying it on only one would mean it didn't take effect if that dn was in use at the time and the call was therefore ringing on one of the alternative dns?
Hi Jim.
Sorry for my bad Explanation
Yes call forward rules have to be applied on both shared line ephone-dn 9 and ephone-dn 10
Carlo
Thanks very much. I think I have enough information to do what I want now.
Sorry, one more thing.  The default do-not-disturb button behaviour I'm getting with this setup seems undesirable. When the phone is on the hook and put into DND "mode" by pressing the DND button, behaviour is correct: hunt group calls are visible on-screen but do not ring that phone. All other phones in the group (i.e. with those overlays) ring OK.
However, when the phone is actually ringing, DND is an option on-screen. If an agent does not want to be disturbed and presses it and a call-forward noan is configured the call is immediately treated as a no-answer and forwarded, rather than just silencing it and giving other agents a chance to answer. When no call-forward noan is configured, the behaviour is correct.
Any ideas how to get around this other than getting rid of the no answer timeout (which I don't want to do), or do you just have to use a proper hunt group instead of the overlays?
Hi Jim,
You may ultimately prefer using a straight up Hunt Group setup, you could
probably mitigate the DND issue by changing the "Ringing" config on the
Softkey Template and removing the DND option
SUMMARY STEPS
1. enable
2. configure terminal
3. ephone-template template-tag
4. softkeys alerting {[Acct] [Callback] [Endcall]}
5. softkeys connected {[Acct] [ConfList] [Confrn] [Endcall] [Flash] [Hlog] [Hold] [Join] [LiveRcd] [Park] [RmLstC] [Select] [TrnsfVM] [Trnsfer]}
6. softkeys hold {[Join] [Newcall] [Resume] [Select]}
7. softkeys idle {[Cfwdall] [ConfList] [Dnd] [Gpickup] [Hlog] [Join] [Login] [Newcall] [Pickup] [Redial] [RmLstC]}
8. softkeys remote-in-use {[CBarge] [Newcall]}
9. softkeys ringing {[Answer] [Dnd] [HLog]}
10. softkeys seized {[CallBack] [Cfwdall] [Endcall] [Gpickup] [Hlog] [MeetMe] [Pickup] [Redial]}
11. exit
12. ephone phone-tag
13. ephone-template template-tag
14. end
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
Example:
Router(config)# ephone-template 15
Enters ephone-template configuration mode to create an ephone template.
template-tag—Unique identifier for the ephone template that is being created. Range is 1 to 20.
Step 4
Example:
Router(config-ephone-template)# softkeys  alerting Callback Endcall
(Optional) Configures an ephone template for soft-key display during the alerting call state.
You can enter any of the keywords in any order.
Default is all soft keys are displayed in alphabetical order.
Any soft key that is not explicitly defined is disabled.
Step 5
Example:
Router(config-ephone-template)# softkeys  connected Endcall Hold Transfer Hlog
(Optional) Configures an ephone template for soft-key display during the call-connected state.
Step 6
Example:
Router(config-ephone-template)# softkeys  hold Resume
(Optional) Configures an ephone template for soft-key display during the call-hold state.
Step 7
Example:
Router(config-ephone-template)# softkeys  idle Newcall Redial Pickup Cfwdall Hlog
(Optional) Configures an ephone template for soft-key display during the idle state.
Step 8
Example:
Router(config-ephone-template)# softkeys  remote-in-use CBarge Newcall
Modifies the order and type of soft keys that display on an IP phone during the remote-in-use call state.
Step 9
Example:
Router(config-ephone-template)# softkeys  ringing Answer Dnd Hlog
(Optional) Configures an ephone template for soft-key display during the ringing state.
Step 10
Example:
Router(config-ephone-template)# softkeys  seized Endcall Redial Pickup Cfwdall Hlog
(Optional) Configures an ephone template for soft-key display during the seized state.
Step 11
exit
Example:
Router(config-ephone-template)# exit
Exits ephone-template configuration mode.
Step 12
ephone phone-tag
Example:
Router(config)# ephone 36
Enters ephone configuration mode.
phone-tag—Unique sequence number that identifies this ephone during configuration tasks.
Step 13
Example:
Router(config-ephone)# ephone-template 15
Applies an ephone template to the ephone that is being configured.
Step 14
end
Example:
Router(config-ephone)# end
Returns to privileged EXEC mode.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesoftk.html#wp1010972
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
2784
