ephone hunt group
I am having issue with the timeouts on a hunt group I have been searching the internet but I can not find anything.
The issue is that I would like to first phone to ring 3 times, then the second one the same and the 3rd phone the same. I have tried to change the timeout several times to different configurations but it does not work properly. It rings on the first phone fine and then the second one rings only once and then goes to the third straight.
Any ideas?
ephone-hunt 4 sequential
pilot 450
list 220, 221, 222
final 225
timeout 3, 3, 20
Hall of Fame Super Silver
ephone hunt group
The values are in seconds not ring times, how long do you want each memeber to ring for?
Chris
ephone hunt group
Sorry, yes there are seconds. I have tried to change the timeout to:
timeout 5,5,5
also to
timeout 10,10,10
and still nothing changes, the second phone rings once and goes to the next phone.
Very strange.
ephone hunt group
Hmm, what version of IOS are you running?
Chris
ephone hunt group
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.0(1)M2, RELEASE SOFTWARE (fc2)
ephone hunt group
That is first 15 release, which I urge you to get a way from, you might be running into some bugs.
HTH,
Chris
153
