10-20-2014 01:22 PM - edited 03-17-2019 12:37 AM
I have a 7960 phone that will not register. There is no ephone in the configuration with that MAC however when I issue a sh ephone CLI, the MAC is listed as below. Note the lack of a primary_dn. The IP listed does not reply. Is there a way to force remove or clear a stuck ephone registration (without rebooting the CME)?
ephone-43[42] Mac:0015.F960.4824 TCP socket:[44] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 11/9 max_streams=0
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:1 paging 0 debug:0 caps:8
IP:172.XX.XX.XX * 50407 Telecaster 7960 keepalive 331003 max_line 6 available_line 6
Preferred Codec: g711ulaw
Lpcor Type: none
10-20-2014 02:35 PM
Hi.
Please post a show run | s telephony and show run | s ephone
Also share a show phone sum det
Carlo
10-20-2014 02:48 PM
telephony-service
sdspfarm units 4
no auto-reg-ephone
max-ephones 65
max-dn 65
ip source-address 172.XX.XX.XX port 2000
max-redirect 5
system message BHFS Phoenix
url services http://172.XX.XX.XX/voiceview/common/login.do
url authentication http://172.XX.XX.XX/CCMCIP/authenticate.asp
cnf-file location flash:
load 7915-12 B015-1-0-4.SBN
load 7915-24 B015-1-0-4.SBN
load 7937 apps37sccp.1-4-3-0.bin
load 7962 SCCP42.9-1-1SR1S.loads
load 7975 apps75.9-1-1TH1-16.sbn
load 6921 SCCP69xx.9-1-1-0.loads
time-zone 7
voicemail 4050
max-conferences 8 gain -6
moh "flash:silence.wav"
multicast moh 239.10.16.4 port 2000 route 172.XX.XX.XX
web admin system name xxxxx secret 5
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
secondary-dialtone 9
directory entry 1 4151 name BHFS-Phoenix
create cnf-files version-stamp 7960 Apr 29 2012 13:42:01
The show run | s ephone isn't going to show you anything because there is no ephone 43 in the config (running or start) hence my confusion of why the not working ephone shows up in a show ephone ( and as resistered no less)
ephone sum det shows the same entry as I listed above
Not working
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:1 paging 0 debug:0 caps:8 NOTE primary_dn: XX* is missing
Working
ephone-41[40] Mac:0015.C616.B521 TCP socket:[20] activeLine:0 whisperLine:0 REGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0 privacy:1 primary_dn: 41*
IP:172.XX.XX.XX * Telecaster 7960 keepalive 1005875 music 0 1:41
Lpcor Type: none
10-20-2014 02:56 PM
Hi.
Have you tried to configure ephone 43 with a dummy Mac address?
if yes, does the router accept the config?
Can you please specify your current version?
Carlo
10-21-2014 02:33 PM
First, thank you Carlo for your replies.
I did not try the dummy MAC. I ended up just using that ephone and mapping the ephone-DN (out of sequence but the system has 6 months before it is replaced).
I think the actual question I had was 'Is there a CLI in the CME router (IOS 15.2(3)T - Telephony 8.8) that allow me to clear a SCCP registration like I can with a SIP registration. (At least I recall doing that at one point). With our affecting all other phones'
I knew what the issue was / is, just don't know if it is possible to clear without a reboot.
I could be crazy, who knows. (not me...or me)
