09-20-2009 01:16 AM - edited 03-15-2019 07:49 PM
When a voice gateway is in MGCP mode, "sh isdn ac" doesn't work.
Is there a way to get similar information ?
The closest I've come up with is "sh voice port sum" (Which isn't great)
GTG
09-20-2009 03:00 AM
With MGCP, call-control intelligence is taken away from the router, so its ability to tell you what's going on will become very limited.
So, either use H.323, or look into the CUCME for any kind of monitoring and statistics information.
09-20-2009 05:04 PM
'show call active voice brief' can be helpful, but when the ISDN b-channel is back-hauled to CUCM there is no way for the gateway to know the ISDN details. So the gateway will know which ports are in use, but no calling/called numbers.
-nick
