08-01-2008 08:56 AM - edited 03-15-2019 12:21 PM
We have CCM 6.1.0 and I set up a device with DN 8262. I deleted the device from Call Manager but need to delete the DN 8262. Where do you do this please?
08-01-2008 08:58 AM
08-01-2008 09:00 AM
David, that is not correct. Starting from CUCM 4.1 DNs are not completely erased when you delete a device.
you need to go to the route plan report, select unassigned DNs and delete them from there. think of it as a recycle bin
java
if this helps, please rate
08-01-2008 09:09 AM
Yes you are correct the Route Plan Report is exactly what I was looking for.
When I call the number now I get a busy signal even though is is deleted. I assigned the DN to a Digital Phone and you can call the the extension from digital phones but when you try to call from an ip phone you get a busy signal.
08-01-2008 09:33 AM
wow, this is a big change and I had no idea... tells you how much time I spend in the UCM. thank you for the education.
david
