Error access DC Directory
I have Call Manager 4.1.3. I need to access the DC Directory but I get an error
DCD16100100: Failed to load schema from server
Any ideas.
Re: Error access DC Directory
Have you checked DCD is running and you're using the right credentials???
I'm assuming you're not AD integrated right?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
If it is AD integrated do I access to retrieve personal directory and fast dial information. Are these information stored in AD? Do I have to stop the AD integration?
344
