Error / Car Scheduler / Physical Log size 20000 is too small.
CUCM version : 8.6.2 on vmware.
Every day at 1H, I've got theses two warnings :
At Fri Dec 30 00:56:36 CET 2011 on node 192.168.80.20, the following SyslogSeverityMatchFound events generated:
SeverityMatch : Critical
MatchedEvent : Dec 30 00:56:11 pbxtela01 local7 2 : 1: padeobxtela01.hq.corp.leroymerlin.com: Dec 29 2011 23:56:11.342 UTC : %UC_CAR-2-CARIDSEngineCritical: %[ClassID=pbxtela01_car8_6_2_20000_2-7][ClassMsg=Dynamic Server Initialization failure.][Specific-Msg=WARNING! Physical Log size 20000 is too small.           Physical Log overflows may occur during peak activity.           Recomme][AppID=Cisco CAR Scheduler][ClusterID=][NodeID=padeobxtela01]: Pay Attention. This alarm does not compromise data or prevent the use of the system.
AppID : Cisco Syslog Agent
ClusterID :
NodeID : pbxtela01
TimeStamp : Fri Dec 30 00:56:11 CET 2011
ClassID : pbxtela01_car8_6_2_20000_2-7 ClassMsg : Dynamic Server Initialization failure.
Specific-Msg : WARNING! Physical Log size 20000 is too small.
         Recomme
AppID : Cisco CAR Scheduler
ClusterID :
NodeID : pbxtela01
TimeStamp : Fri Dec 30 00:56:11 CET 2011.
The alarm is generated on Fri Dec 30 00:56:11 CET 2011.
Is there a solution two avoid these two messages ?
Best regards.
Everyone's tags (3)
Re: Error / Car Scheduler / Physical Log size 20000 is too small
I am seeing the same problem on my 8.6.2.20000-2 server.  Any resolution to this?
the messages disappeared all alone.
Best regards
Searched and found the information as below.
The reason of the physical log overflow is below:
The physical log can overflow if you use simple large objects or smart large
objects in a database with transaction logging turned off, as the following
example shows.
When the database server processes these simple large objects, each portion
of the simple large object that the database server stores on disk can be
logged separately, allowing the thread to exit the critical sections of code
between each portion.  However, if logging is turned off, the database
server must carry out all operations on the simple large object in one
critical section.  If the simple large object is large and the physical log
small, this scenario can cause the physical log to become full.
However, there is no action required due to no system impact.
Recommended minimum Physical Log size is 160 times maximum concurrent user
threads.
This alarm is not a concern, there was no system or database problem.
I am also getting this issue on 8.6.2asu2 system.  I found this bug:
CSCtt44392 Bug Details
Increase log file size for informix in CAR
Symptom:
RTMT alert is generated:
ClassID : se015a_cm21a_car8_6_2_21001_1-7
Recomme
Conditions:
Upgrade was done to 8.6.2 ES and we see this alert in RTMT.
Workaround:
None. It is not service effecting.
4214
