**ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
Hi All,
I am now facing issue with calling to outside network through isdn E1. Could you check the below debugs and help me here?
Mar 19 07:38:05: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 83573065
Mar 19 07:38:05: ISDN Se0/3/0:15 Q931: Sending SETUP  callref = 0x0080 callID = 0x8001 switch = primary-net5 interface = User
Mar 19 07:38:05: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0080
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0081, '83573065'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '10274826016'
Mar 19 07:38:09: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0080
                Standard = CCITT
Mar 19 07:38:13: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0080
        Cause i = 0x80E6 - Recovery on timer expiry
Mar 19 07:38:13: ISDN Se0/3/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
I am getting busy signal when I make call.
Lajith
5 Replies 5
Dragan Ilic
Level 4
Level 4
As I can see you're not receiving CALL_PROC message from provider...btw you're not receiving anything from them. What "sh isdn status" tells you? Are incoming calls working?
HTH,
Dragan
HTH,
Dragan
The incoming is handled by another gw/pri so I was not able to check on that. Here is the isdn logs.
nezrt001#sh isdn status
Global ISDN Switchtype = primary-5ess
ISDN Serial0/3/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80007FFF
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
I can only suggest you to contact your provider about this because you are not receiving nothing from them...maybe you can try replacing some interconnecting cables between your equipment and telco.
HTH,
Dragan
HTH,
Dragan
You should contact your Service Provider, it seems that is forbidden to make outgoing calls. I have already seen this a lot of times.
Maybe you have to unblock the contract to be able to generate traffic subject to tariff.
Ulderico
fpavicic
This is definitely provider issue, they didnt map numbers correctly.
