Community Member
Error: GetNewFileName-fopen in wb mode failed to update existing file
The entire message I am getting in my application event logs is "Error:GetNewFileName-fopen in wb mode failed to update existing file. szFileNumberName=E:Traces\DBL\DBL_CTFTP~num.bin." It seems to a permissions issue not allowing access to write to trace files. Has anyone seen this and knows how to fix the permissions?
1 REPLY
Bronze
Re: Error: GetNewFileName-fopen in wb mode failed to update exis
You may be hitting with this bug:CSCed38443
475
