error in Unity 4.1
hi
i have installed unity 4.1 with exchange 2K on a PC in my Lab, with this PC being the domain controller, everything in the installation went correctly without errors as documented in the installation procedure for ciwsco unity 4.1, but after every thing was installed, I tried to start unity from its icon located below in the task bar, but as soon as it is trying to go up, it immediately goes down with an x mark on the Unity icon ...
please does any one has any idea I should perform to troubleshoot this problem?!
thanks
Re: error in Unity 4.1
any updates pleaase
Check all the Unity services and see if they are running under Administrative Tools | Services. Then also have a look in the Event Viewer because I suspect it's a permissions problem with one or more of the Unity accts.
-Erik
94
