03-02-2008 12:09 PM - edited 03-15-2019 09:10 AM
hi,
i am getting this error in callmanager for past two days and before that it was never there.
IPMA and Extn Mobility is also not working.
i searched this error but not able to understand how the password changed when it was working fine somedays back.
thanks for your support.
03-02-2008 01:33 PM
Hi Sandeep,
Sorry to hear that you are having problems. This error doesn't necessarily mean that the password changed, just that it is out of sync between servers. There are some great ideas to fix this from Jorge and Rafael in this thread;
Hope this helps!
Rob
03-02-2008 10:32 PM
hi thxx for your prompt reply.
my error code is bit different from the link u have provided rest is same.
Reason code.: 1932787616
