error message during Unity 4.0(5) install, need guidance
All, Ive been working with this all day. I get about 30 minutes or so into the install, and it bombs out. Here is what the error message says, see attached. I have had sql 2005 (not suported) and now I have msde2000 running. Still same issue. Doing a Unity 4.0(5) install. Anyone seen this?
1 ACCEPTED SOLUTION
Re: error message during Unity 4.0(5) install, need guidance
It is possibly that you are running into the following bug, it was first found in release 4.0.5 and is the closet match that I could find:-
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsb57898
Verify whether you running into the same conditions decscribed in the bug? If this is not the case, and none of these are applicable, then I would suggest you raise the problem with TAC.
Allan.
By the way, I have uninstalled IE7, and currently have MDSE 2000. Just more FYI. Thanks for reviewing this.
Allan.
That was it. You nailed it. Thanks.
No problem, thanks for rating :-)
Allan.
98
