error message on CM413
Warning: IIS log failed to write entry, Script timed out. The maximum amount of time for a script to execute was exceeded. You can change this limit by specifying a new value for the property Server.ScriptTimeout or by changing the value in the IIS administration tools..
I'm having this error log from Application Log. It is showing up every day or so? Do you know on to fix that up?
Tks,
yanci
1 REPLY
Silver
Re: error message on CM413
you are hitting CSCeb80203
Symptom:
The following warning is observed repeated in the Application Log in the
Event Viewer:
Event Type: Warning
Event Source: Active Server Pages
Event Category: None
Event ID: 9
Date: 6/25/2003
Time: 12:49:42 PM
User: N/A
Computer: CM-PUBLISHER
Description:
amount
the
For additional information specific to this message please visit the
Microsoft
Online Support site located at:
http://www.microsoft.com/contentredirect.asp.
This warning is followed by the following information message:
Event Type: Information
Event ID: 4
Date: 6/25/2003
Time: 12:49:44 PM
User: N/A
Description:
Service stopped.
Conditions:
This appears 20-21 minutes after the last access to a web page.
Workaround:
There is no known workaround. However, is no noticible impact other than the
presence of this warning in the App Log.
144
