02-28-2012 04:33 AM - edited 03-16-2019 09:49 AM
I Guys,
I installed the VMWare 4.1 in a one Server UCS C210. After this install I did the installation CUCM version 7.1.3 and didn´t had problem. When I Tried to do the upgrade I received the message error: "Error encountered: The selected upgrade is disallowed from the current version". I Verified the matrix compatibility and saw that is possible to do this upgrade.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Wilson
Solved! Go to Solution.
02-28-2012 06:08 AM
Yes apply this COP file frist and after that upgrade your CUCM.
Ronak patel
02-28-2012 04:41 AM
CUCM 7.1 is not supported on Vmware...
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications
Ronak Patel
02-28-2012 04:50 AM
I believe this is lab deployment. As CUCM 7.1 is not supported in VMware..
Solution for your problem
1) Install COP file ciscocm.refresh_upgrade_v1.0.cop.sgn
Also please note Guest Operating System required for CUCM 8.6.2 is Red-Hat Enterprise Linux 5 (32-bit).
Ronak Patel
02-28-2012 05:55 AM
Hi Ronak,
I am sorry, but, I installed the cucm 7.1.3 in the VMWare and didn´t had nothing problem. My problem is upgrade
Wilson
02-28-2012 05:57 AM
For upgrade you need Install COP file ciscocm.refresh_upgrade_v1.0.cop.sgn
Ronak patel
02-28-2012 06:04 AM
Hi Ronak,
I have that apply first this upgrade (ciscocm.refresh_upgrade_v1.0.cop.sgn) and after apply the cucm upgrade 7.1.3 for 8.6.2?
Wilson
02-28-2012 06:08 AM
Ronak patel
02-28-2012 09:10 AM
Hi Ronak,
I applied the file that You recommended for me and after installed the upgrade CUCM 7.1.3 for 8.6.2 and it worked.
Thank You Very Much,
Thanks a lot
Wilson
