Error Message
Has anyone ever seen
Registration Rejected:Error Misma...
If so, how do you fix?
1 ACCEPTED SOLUTION
Re: Error Message
you're trying to configure a phone using a wrong model
ie you have a 7941G and you used 7941G-GE when registering it
use the right model or use auto-registration
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Error Message
java
java
Re: Error Message
If you have a regular 7941 and are creating IP Phones as 7941G-GE, then you might endup with this error.
137
