Error msg %HWIC_CDSX_MODULE-3-CDSX_IPC_CMD_FAIL:
I just installed a NM-HD-2V (with a SM-NM-ADPTR) in a 2911 router, and now during bootup process I have the following msg:
000062: *Jun  1 18:38:22.323: %HWIC_CDSX_MODULE-3-CDSX_IPC_CMD_FAIL: IPC Command (message type:0x1, opcode:0xD) to the firmware Failed on slot(0) subslot(0) due to IPC Hold Q Full
000063: *Jun  1 18:38:22.323: %HWIC_CDSX_MODULE-3-CDSX_IPC_CMD_FAIL: IPC Command (message type:0x1, opcode:0xD) to the firmware Failed on slot(0) subslot(0) due to IPC Hold Q Full
In slot(0) subslot(0) I have a VWIC3-4MFT-T1/E1,
I do not remember to have seen this msg before, the only recent change is the new NM-HD-2V.
I just want to know what this message means and if is something that I have to worry about or not.
Here is the #sh invent
TEST1#sh inventory
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V02 , SN:
NAME: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-4MFT-T1/E1 - 4-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-4MFT-T1/E1  , VID: V01 , SN:
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN:
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN:
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 3", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1  , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128         , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN:
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN:
NAME: "High Density Analog Voice Network Module on Slot 1", DESCR: "High Density Analog Voice Network Module"
PID: NM-HD-2V          , VID: V01 , SN:
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V03 , SN:
TEST1#
Thanks in advance.
Carlito
264
