Error Occured While retrieving information from database.The connection between presence and CUCM Publisher is down
Hi all,
i have new problem,
please help me to solve this out,
thanks
That looks fine, any possibility of rebooting the cucm Pub followed by IM&P?
Manish
10 Replies 10
Manish Gogna
Hi Alpert,
What is the exact cucm version. Can you check the output of "show status" on both CUCM and IM&P Pub and also see if any imp services are stopped on them.
Manish
hi manish,
thanks for replied,
show status in cucm
Product Ver : 10.5.2.11900-3
Unified OS Version : 6.0.0.0-2
Uptime:
18:53:02 up 85 days, 23:38, 1 user, load average: 0.20, 0.24, 0.18
CPU Idle: 54.82% System: 10.66% User: 34.51%
IOWAIT: 00.00% IRQ: 00.00% Soft: 00.00%
Memory Total: 5994188K
Free: 122756K
Used: 5871432K
Cached: 1893840K
Shared: 0K
Buffers: 169080K
Total Free Used
Disk/active 20061388K 7225080K 12632492K (64%)
Disk/inactive 19743212K 7024016K 12515380K (65%)
Disk/logging 82569840K 37716264K 40659276K (52%)
show status in presence
Product Ver : 10.5.2.20000-1
Uptime:
18:54:35 up 9 days, 4:49, 1 user, load average: 0.17, 0.04, 0.01
CPU Idle: 90.72% System: 02.06% User: 07.22%
Memory Total: 5993940K
Free: 257492K
Used: 5736448K
Cached: 2561536K
Shared: 0K
Buffers: 195756K
Total Free Used
Disk/active 20061388K 9971760K 9885812K (50%)
Disk/inactive 19743212K 14448708K 5090688K (27%)
Disk/logging 82569840K 37034456K 41341084K (53%)
there are no stop service
thanks
Alpert
Manish
thanks manish to the respons,
thats not possible,
my company man forbids me to reboot the server.
any service in cucm must be to restart ?
thanks
Try restarting Cisco Sync Agent service under Network services on IM&P and see if that helps, else you should open a TAC case to investigate further if there are no further inputs on this post.
Manish
thanks manish for the suggest,
but service ability cannot be open, please see the attachment above,
open tac is disable here because out of service.
thanks
Alpert
hi all,
my problem was solved, by restart server.
thanks all
Hi Alpert,
Can you please let me know which server did you restart to resolve the issue.
I'm getting the same error:
"Error Occured While retrieving information from database.The connection to the CUCM Publisher is down"
Please let me know if you restarted CUCM PUB or IMP server or both ?
Thank you
Saima
Jaime Valencia
Are they in the same physical location?
java
if this helps, please rate
hai jaime thanks for respons,
yes they are
what should i do?
thanks
