Error on CM6BE Real Time Monitor
A customer has reported that the Real Time Monitor is reportings
"hwStringMatch - HP Storage Manager Agent: Commands are not responding: controller 1 "
I have searched Cisco and Google on this but am unsure what it means, any ideas
Thanks in advance.
1 ACCEPTED SOLUTION
Re: Error on CM6BE Real Time Monitor
that probably is a HW error from a HDD or from the actual array controller. i'd recommend you to open a TAC case so they can gather some show commands outputs and get in touch with HP if necessary
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
many thanks for this, I will contact our hardware support guys.
Rich
401
