Error on IBM server
I have an MCS 7835I04 (IBM server) that has an amber exclamation light on the front of it. Both hard drives look good and I do not see anything in the event logs. Does anyone know how I can find out what is causing this light? Are there any IBM utilities I can use to view errors?
Glenn
Green
Re: Error on IBM server
Hello Glenn,
Which LED is it that is showing as amber? If it is the second LED from the top (assuming
all four lights are in a column at the front panel, rather than a row of lights), then
this would be an indicator that there is no power redundancy (which could be a bad power
cable, a bad power supply, or simply that the second power supply is not plugged in at
all).
In the CD Media Box that is shipped with the server there should be a white CD with system Tools for HW Diagnostics
I'm currently remote to the server and do not remeber exactly which light it is. If it is a power supply problem, wouldn't that show up in the event logs?
Glenn
On one of our servers, we opened up the case (with it running) and found that there was an amber light next to one of the memory modules. In our case, we moved the memory modules to different slots (to see if the module or the slot was bad) and the problem was solved. We also didn't see any errors in Event Viewer with this.
430
