Error opening tftp://.......................(timed out) UC500 loopback network
Hello all,
When I try to access areas through CCA (cisco configuration assistant) such as ringtones or backgrounds for the phones, I get an error message. I have attached a screenshot of the error I get
Anyone have any idea as to how I can fix this?
1 ACCEPTED SOLUTION
Green
Re: Error opening tftp://.......................(timed out) UC50
Jason,
Firstly thanks for you patience.
We have located the issue to the default gateway of the PC not having ip routes to UC500/CUE.
So it is not always thye rocket science that is the issue.
Alex
Please rate and mark as correct answer if this helped
Regards, Alex. Please rate useful posts.
Green
Jason,
This looks to be a routing issue.
Can you display the running config of the router.
Regard
Alex
I updated the original post which now has the config attached.
Thank you,
Jason
Green
Jason,
This an ip routing issue
You have
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly
This loopback consumes the whole network 10.1.10.0 (SubNet = .0 host .1-.2 broadcast. 3)
Your service module is clashing with the loopback
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
You could try deleting the loop back and use the subnet as an interface vlan instead.
Save you config as it is then try
no int loop 0
int vlan 101
desc CUE SUBNET
ip nat inside
no shut
Give it a test if it fails put it back and we can look again.
Alex
I'm a new guy so one question I have is..
Could this potentially cause any problems with incoming/outgoing calls? If not I will do it right now, but if so I will have to do it after hours.
Green
Jason,
Sorry.
Can you hold fire on this.
I want to check a few things from your config in the morning.
Alex
No worries. I appreciate the help.
Green
Jason,
Can you provide the output of
show ip route
from the UC500
I dont think it will be very big so you should be able to paste it into the blog.
I still want to check more items in your config but I need to see the ip routing table.
I am trying to keep the required changes to a minimum.
Alex
FPP-UC520-HQ01#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 69.199.54.81 to network 0.0.0.0
     69.0.0.0/29 is subnetted, 1 subnets
C       69.199.54.80 is directly connected, FastEthernet0/0
     10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
S       10.1.10.1/32 is directly connected, Integrated-Service-Engine0/0
C       10.1.10.0/30 is directly connected, Loopback0
C       10.254.0.96/27 is directly connected, Vlan999
C    192.168.1.0/24 is directly connected, Vlan10
C    192.168.100.0/24 is directly connected, Vlan100
S*   0.0.0.0/0 [1/0] via 69.199.54.81
Green
Thanks Jason,
What is the IP address of your PC ?
Can you ping 10.1.10.1 ?
Can you ping 10.1.10.2 ?
Alex
My IP is    192.168.1.120
Pinging 10.1.10.1 gives me this result
Pinging 10.1.10.1 with 32 bytes of data:
Reply from 38.20.63.45: Destination host unreachable.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.10.1:
    Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Pinging 10.1.10.2 just times out
Pinging 10.1.10.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.10.2:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Green
Thanks again Jason.
My last questions for today.
Is your PC default gateway 192.168.1.5 ?
Can you ping 192.168.100.1 ?
I still think the CUE service module is IP clashing with loopback 0
We need loopback0 as it is referred to by other interfaces.
We also need the 10.10.1 address as this the CUE address used for the VM dial peers & viewmail etc.
My idea is now to try some changes.
I just need more info before I send these out.
Alex
Default gateway is 192.168.1.9
IPv4 Address. . . . . . . . . . . : 192.168.1.120
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.9
Pinging 192.168.100.1 give this result:
Pinging 192.168.100.1 with 32 bytes of data:
Reply from 38.98.1.1: TTL expired in transit.
Ping statistics for 192.168.100.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Green
Jason
I have sent you a message via the forum mail service privately. Can you respond ?
Alex
responded
Green
Jason,
Alex
Thank you for the prompt responses. I couldn't have asked for better help
Jason
2728
