%Error, "tftp://cme-gui-4.0.0.1.tar" is a directory.
i am getting this error while extracting the .tar file to flash.
thx for consideration.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: %Error, "tftp://cme-gui-4.0.0.1.tar" is a directory.
there is a bug with these symptoms, CSCek63178. However is not clear if it has been fixed. Try extracting te file on another router and then copy them manually.
thx i extracted this on pc and copied one by one all files..
thx
Absolutely. And the bug says "no workaround" ?!?
C'mon cisco, you can do better than that!
Thanks for the nice rating and good luck!
312
