Error SIP 404 Not Found
Hi All,
I have a problem with my Call Manager trunking to Avaya. Calling to PSTN is routed to trunking Avaya with Pattern 0.!
the problem was if i dialed pattern to some our provider like 0878XXXXXXXX , the call was unsuccesfull. but for number of other provider was succesfull. I tried to monitor from RTMT and got this logs :
//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 10.12.3.16 on port 5060 index 2 with 363 bytes:
SIP/2.0 404 Not Found
From: "Anju" <sip:9999@10.12.3.205>;tag=25be35fe-f935-4a4c-9f3c-bdaacddcf9dd-32039991
To: <sip:0087877820808@10.12.3.16>;tag=06b27413d7e116544f6f5b4800
Call-ID: df235100-ffa15cd3-40-cd030c0a@10.12.3.205
CSeq: 101 INVITE
Via: SIP/2.0/TCP 10.12.3.205:5060;branch=z9hG4bK72716a683c
Server: Avaya CM/R014x.00.5.742.0
Content-Length: 0
could you help me, what causes this problem happen?
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
You should look in the other system why certain calls fail. It has nothing to do with the Cisco.
Hi Paolo,
Thanks for your reply.
yup you're right. after i checked, there was problem at avaya.
Thank you for the nice rating and good luck!
not the correct answer...something with your SIP profile, i am stil troubleshooting the issue.
2555
