Hello Khurram
Looks like hitting this bug.
Include partition alignment check in "VMware Installation" CLI & GUI
CSCug69836
Symptom:
Need to be able to readily identify if a system has been installed and deployed in a supported way on VMware with regards to disk alignment.
Modify CLI and GUI VMware information to check and include this.
Existing example string:
VMware Installation: 2 vCPU Intel(R) Xeon(R) CPU X5680 @ 3.33GHz, disk 1: 80Gbytes, 4096Mbytes RAM
Proposed string (aligned):
VMware Installation: 2 vCPU Intel(R) Xeon(R) CPU X5680 @ 3.33GHz, disk 1: 80Gbytes, 4096Mbytes RAM, Partitions aligned
Proposed string (unaligned):
VMware Installation: 2 vCPU Intel(R) Xeon(R) CPU X5680 @ 3.33GHz, disk 1: 80Gbytes, 4096Mbytes RAM, ERROR-UNSUPPORTED: Partitions unaligned
Conditions:
UCM installed on VMware
Workaround:
1. UC on VMWare must be deployed with Cisco provided OVA. This is the only way to ensure aligned partitions. Manually creating VM is insufficient.
Check the bug history for more details
Br,
Nadeem Ahmed
Br,
Nadeem
Please rate all useful post.
