Error when adding Subscriber to Cluster
I am adding a subscriber MCS7835 5.1.3 to a Cluster over WAN (MPLS - no firewall between). The error screen appears (see attached JPEG) during subscriber setup and Publisher reports the error below - Help would be really helpfull:
Date: Oct 6 16:58:38
Machine Name: xxxcm1001
Severity: Error
Process:
Message:  599 Oct 06 145838.26 UTC   %CCM_CLUSTERMANAGER-CLUSTERMANAGER-3-CLM_MsgIntChkError ClusterMgr message integrity check error.  Sender's IP address10.109.50.12 App IDCisco Cluster Manager Cluster ID Node IDxxxcm1001
Pings are ok:
xxxRT1000#ping vrf CIO 10.104.93.11 size 1500 repeat 100
Sending 100, 1500-byte ICMP Echos to 10.104.93.11, timeout is 2 seconds:
Success rate is 83 percent (50/60), round-trip min/avg/max = 12/12/12 ms
Just traffic is not correctly marked and go in Default traffic:
amsqs1001# traffic flow -tupixCA  10.104.93.11
Num TCP Flows total   =      1 (all classes)
InAddr           Port  OutAddr          Port Idle ClasI ClasO Svc
10.109.50.12     1099 10.104.93.11    55948  5s  /Inbound/Default /Outbound/Default -
Num UDP Flows total   =      2 (all classes)
10.109.50.14    25757 10.104.93.11     8500  23m  -  /Outbound/Default -
10.109.50.12     8500 10.104.93.11     8500  4s  /Inbound/Default /Outbound/Default
Many thanks
Everyone's tags (1)
Re: Error when adding Subscriber to Cluster
Correct me if I'm wrong, but you are losing every sixth ping.  If you have a drop rate of 16%, there are going to be problems with UDP.  I mean, TCP would also have problems, but those would be masked somewhat.
Considering it is every sixth packets, I would guess there is some packet shaping and/or policing going on.
Thx ccharlebois, I will raise the point to network team.
JPB
Most of the time, this is due to MTU mismatch between the nodes.
What is the mtu on pub and whats the limit over WAN.
BTW, do you have the sub added under system>server of pub?
How many nodes in the cluster? What is the status of replication?
Do the security passwords match ?
You can also try restarting cluster manager on pub , reboot sub and then try the install again.
Sometimes the Pub can get into a bad state and prevent nodes from
joinin
g -"admin:utils service restart Cluster Manager"
-Sajjit
Hi Sajjit,
Many thanks for your help.
What is the mtu on pub and whats the limit over WAN. I will check the config and involve our Global Network Team!
BTW, do you have the sub added under system>server of pub? Yes
How many nodes in the cluster? 1 pub + 2 sub + 1 I need to add. What is the status of replication? The status is correct, just the new subscriber is not in the replication process.
Do the security passwords match ? Yes
You can also try restarting cluster manager on pub , reboot sub and then try the install again.  Really good point!
joinin
I will come back to you with answer to differnet investigation, I just have to wiatthe next available window next Monday.
JP
1041
