Errors in syslog
Hello.
I have CUCM 8.6.2.24901-1
There's messages in syslog every 10-20 seconds as follow:
ccm: 239607: CCM: Aug 06 2014 11:36:05.223 UTC : %UC_CALLMANAGER-3-DbInfoError: %[DeviceName=][ClusterID=CCM-Cluster][NodeID=CCM]: Configuration information may be out of sync for the device and Unified CM database
Is it a way to fix that error?
1 ACCEPTED SOLUTION
yes. state is 2 on all nodes
VIP Gold
Does dbReplication is fine
Does dbReplication is fine (stat 2) at all node ?
Suresh
Do a "utils dbreplication
Do a "utils dbreplication repair all" on the publisher. This should fix it.
Hi, I have the same problem
Hi, I have the same problem in one of the subscribers, it has also the VM Memory around 90% and I don´t know if this could be the cause.
Could I have any problem if I run this during business hours?
Thank you!
Hello.I guess your
Hello.
I guess your dbreplication status on the cluster should be 2. This might be due to a mismatch in some tables.
Please do "utils dbreplication repair all" on the publisher. What this command does is to match tables with configuration between publisher and all other nodes and correct any mismatches. This should solve it.
repair didn't fix
repair didn't fix anything
xxxx:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication repair command started at: 2014-08-06-19-24
     Replication repair command COMPLETED 541 tables processed out of 541
     No Errors or Mismatches found.
errors continue at the same rate
Re: repair didn't fix
Did you ever solve this issue?
I have the same problem after upgrade from 11.5SU1 to 11.5SU3.
Every 2 minutes this syslog message is generated, all DBs have the state 2 and are fine.
Any idea?
427
